Clamp Output on 2.0 give me edge aliasing
  • Clamp Output on 2.0 give me edge aliasing
    I've noticed that Clamp Output with a default setting of 1 will now create nasty aliasing on high contrast edges. You then need to increase the setting to at least 2 in order to clean up those edges. Unchecking Clamp Output/increasing the setting also increased rendertimes slightly.
    What's the reason for this new strange aliasing?
    Which V-Ray version is this?
      Hi Vlado, I'm on 2.00.02
        If I kick the Clamp output up to 1.8 or so, the problem goes away.
        Vlado, any thoughts? Is this a bug?
          There is a bug with the "clamp output" in the original V-Ray 2.0 release; it is fixed for the service pack, but in the meantime, you can either not use it, or else create an environment variable called "VRAY_OLD_SAMPLING" with value "1" without the quotes, which will tell V-Ray to use the 1.5 sampling algorithm.
            Okay, did the variable method and all appears well.
            Tnx, Vlado.
              Vlado, where do we stand with this bug? Was it addressed in the new SP1? Tnx
                bump. Anyone?
                  Yes, it should be fixed in the service pack.
