Instanced animated V-ray proxy problem - consumes all the available RAM!
  • Instanced animated V-ray proxy problem - consumes all the available RAM!
    I have to make a representation of a series of animated dendrites. I made a grow thingy using Pflow spawning a series of spheres (see attached image). Since it's a constantly changing geometry, the only way to kind of bake the animation/mesh was through an animated v-ray proxy. The process went fine, and the proxy size was about 700 Mb for a 300 frame animation.
    Everything looked fine until I instanced a few copies. It renders fine with a single proxy, and it also render fine with a bunch of instances on the last frame of the animation.
    But if I try to render any frame in between, the buckets doesn't move, ad the RAM usage maxes out in a few seconds till my system comes unresponsible! The render window dialog states: "rendering image" without any loading/unloading geometry notice.
    From what I understand about animated v-ray proxies, the system should pick the appropriate mesh from the proxy file of the given frame?
    Which V-Ray version is this? Are you sure you instanced the proxies?
      latest v-ray build. I tried rendering the scene both on max 2009 and max 2011
