vraynormalmap error
  • vraynormalmap error
    Not sure what the problem is. I can't seem to set the max parameter for the vraynormalsmaps higher than 30 otherwise I get this error.
    Any reason for this ?
    Regards
    Steve
    My Portfolio
    What is the geometry (regular mesh or proxy)?
      Just a regular mesh with turbosmooth
      Regards
      Steve
      My Portfolio
        Would be best if you can get me a scene then; somewhat hard to say what's going on.
          Will do. Whats your email ?
          Regards
          Steve
          My Portfolio
            Did you get the file I sent Vlado. I really need to get this render sorted for a client...Thanks
            Regards
            Steve
            My Portfolio
              Have a real close look at your normal map......depending how it was produced, you MAY see it is not smooth but looks like it's layered with edges.
              Put it back into photoshop & do a slight Blur & see if that helps
                I used crazybump to create it... I'll take a look at it in photoshop though to see if there are any "features"
                Regards
                Steve
                My Portfolio
                  This is the normal map im using.. looks fine to me.
                  Regards
                  Steve
                  My Portfolio
                    Any progression with this Vlado...my client is getting quite desperate !
                    Regards
                    Steve
                    My Portfolio
                      You have set the gamma for the normal map to 2.2 - this is not necessary. Set it to 1.0 and it will be fine.
                        Doh, silly me. Thanks for letting me know.
                        Regards
                        Steve
                        My Portfolio
                          Maybe it already does by now, but it would be cool if the gamma for a VrayNormalMap was automagically set to 1.0 to avoid this sort of thing. It's not like you would *ever* want a 2.2 normal map...
