vrayedgestex and vray normal map
  • vrayedgestex and vray normal map
    is there a way to comp togheter a vrayedgestex map and a vraynormal map?
    ... if not, do you know any workaround or do I have to switch back to bump maps?
    Alessandro
    did you try using max MIX map?
    Martin
    http://www.pixelbox.cz
      Used the Mix map for that for a few times now, worked well.
        thanks guys for your answers; this trick really works
        As I have always used the vray comp map for tha bump plus edges, when I realized that it didn't work with normals I thought there was a sort of incompatibility among vraynormal and vrayedgestex so I didn't test others composition maps.
        Alessandro
          I comped together two different normal maps using the vraycomp map some time ago, that worked too. Not sure about normalmap + edge texture tho...
