Odd glancing reflection problem
  • #16
    Humh tricky... Ged rid off fresnel and just put 15/15/15 in color ?
    • #17
      If you still have this issue, you can email the scene to our support guys at vray@chaosgroup.com - they will be able to help you out.
      • #18
        Originally posted by dlparisi View Post
        @tricky: Did changing the reflection cutoff fix this for you or we're you able to resolve it some other way. I've got a scene now that the is experiencing the same problem and I've tried changing the material cutoff to 0 as well as every light's cutoff to 0 (just trying everything). Very frustrating.
        Sorry for delay - not been around here for a while. The cutoff value did clear up my problem. I haven't had it since, but as someone I think has said, changeing the value will just move the problem somewhere else. Hopefully distant or out of shot.
        Kind Regards,
        Richard Birket
        http://www.blinkimage.com
        • #19
          Yeah - that's basically what I ended up doing.
          If I can strip it down and still get the error I'll send it along. Thanks for the offer.
          • #20
            I had issue like that once time ago... It was the problem of gamma - maybe u have that same problem?
            • #21
              Problem with the gamma where? in Max's settings or vray's? What should I try changing?
              • #22
                Reset all gamma settings to 1... See if that helps...
                • #23
                  FYI to anyone who's still having any problems. I was able to fix my reflection problem by changing the cutoff value to .001 but I had to change it for the glass material that the sky was visible reflected in. My problem was on a floor that was reflecting a vray skylight and no matter how small I made the reflection cutoff for the floor, I always got a harsh line in the reflection of the bright windows. When I changed the cutoff on the glass to .001 (or to 0) the line went away and I got a nice blurry reflection as expected. Just something to keep in mind.
                  • #24
                    Wonderful, have been experiencing this problem for ages and thought I'd tried everything until I saw this.
                    Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
                    www.robertslimbrick.com
                    Cache nothing. Brute force everything.
