Frame buffer and solid rock problem
  • Frame buffer and solid rock problem
    Once the render is done the frame buffer runs out of memory.
    flicks back and forth, and not responsive .
    12gb or ram, and 1.25gb of graphics card should be enough to handel the job.
    So any idea ?
    Thank you hil
    Vray 2.10
    ell precision 690 12gb
    gtx460 1.25gb
    max 2012
    HDD Space
    Aero causing issues with shadows and so on
      yes. I posted this on the SolidRocks forum, but I never followed up. If you click the "restore down" button, in MAX, you bring focus back to MAX's windows.
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
        Sorry HDD ?
        Aero ?
        being a bit thick here can you explain this to me please.
        So I take it there is no answer to this at the moment ?
        Thank you also for replying
        Phil
          no answer, but you can get focus back to your VRB, just click the middle button in the upper right of MAX.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Hi All, i've noticed this problem on my latest projet, only happening with Vray vfb. i'm trying to find what's wrong.
            Jérôme Prévost.
            SolidRocks, the V-Ray Wizard.
            http://solidrocks.subburb.com
              i sometimes get this without even activating solidrocks
              Martin
              http://www.pixelbox.cz
                thanks for info. Looks like a ram issue ?
                Jérôme Prévost.
                  It's maddening. Some times I have to wait through 5 minutes of flickering to get control back.
                    Sounds like slow HDD or lack of ram...
                      it pointed me to a bad ram settings once...so it can be a ram issue...
                      Martin
                        i'm making some tests with bitmap pager off, to see if it helps.
                        Note : bitmap pager is, in max 2012, only accessible via maxscript.
                        you can have a try if your want, just type in macscript listener : IBitmapPager.enabled = false
                        I'm interested by results
                        and in solidrocks, when using Vray VFB, i'm actually trying to see if i can check OFF the "Get resolution from max" and keep a very low res in max while rendering at high res in Vray VFB. This will save ram. Please correct me if i'm wrong
                        It's a bit complex, as SR is right now strongly tied to the max resolution to compute correct Vray parameters. I tell you informed.
                        Jérôme Prévost.
                          That didn't work for me. This has to be the most annoying bug ever.
                          www.billa1.com
                            I am not to sure it's a SolidRock issue. If you read other threads, on the VFB, there is issue without SolidRocks being used.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              Yeah I know, i just tried Subburbs suggestion of the maxscript listener.I don't even have Solidrocks installed on my computer at work and that's where its happening.
                              www.billa1.com
