even with very less mesh file size is huge!
  • even with very less mesh file size is huge!
    Hello All,
    I am doing a floor plan & suddenly my file became very heavy.. file saving & opening time also become very high.. I noticed my file which includes only few extrude lines & minimalistic furniture is saved as 435 mb! whereas my other files with similar stuff is not more than 40mb in size. To solve problem i started deleting inside stuff one by one & i keep saving file after every delete.. strange but true that even after deleting everything in the file( empty file) my file size is 375 mb! & PF usage is 6gb! i my trying to import everything from this file to new file but 3dsmax hanging.. im stuck.. any solution guys other than redoing everything?
    Prateek Vishwa
    sigpic
    www.prateekvishwa.com
    https://www.facebook.com/pages/PVDS/161239543925007
    Doesn't really seem like a vray problem, but do you have a bunch of turbosmooths on objects? Setting those to render iterations instead of viewport/regular iterations can reduce your filesize by 4x in some cases. (Even more for iterations above 1 or 2). Usually this is the culprit to a bit scene like this, but rig data can also chew up a fairly large amount of space.
    PF usage? Particle flow? Must be some complicated networks in there. You might just try merging everything into a new scene, it's the age old "fix all" when a scene gets crazy. (And they do.)
      Hey thanks but as i said i slowly slowly deleted each & every object in my file.. my file is empty now but still on saving empty file itself is of 375 mb! PF usage as in task manager pf usage.. i tried merging everything to new file but 3ds max hanging..
      Prateek Vishwa
      sigpic
        Sometimes Max just does weird stuff. I have no idea whats causing your problem, but if the merge-thing doesnt work maybe you could try selecting all objects you want to keep, all lights/cameras etc and use "save selected" and save it to a new file. This has saved me before when a file starts acting weird. (havent had your problem though so not sure if it will help)
        k
          Make sure you don't have any residual Physics calculations in the scene. I remember a while back when (it took a while to figure it out) the physics engine cached some data people had empty scenes with 300+mb in them. It's probably cached something...
          Colin Senner
            ahh i see.. but how to check for this? i closed & restarted max & computer still same issue even with empty file.. so i am not sure cache remains even after restarting. I have redone every thing so nothing to worry but still curious to know what was the reason behind this.. i am afraid if this will ever happen to some bigger project where redoing is not possible...
            Prateek Vishwa
            sigpic
              k
              in the emptyfile i made a box, thn i save selected this box.. guess what..this poor box got saved as a file with 375 mb! mysterious max..
              Prateek Vishwa
              sigpic
                I think there is something on "the area" about this.
                If you can't find anything about it I have a maxscript that might work but its only to be used as a last resort
                Chris Jackson
                Shiftmedia
                www.shiftmedia.sydney
                  I already have redone everything so nothing to worry but out of curiosity i dont mind trying your script
                  Prateek Vishwa
                  sigpic
                    what version of max are you using?
                    Chris Jackson
                    Shiftmedia
                      i am using 3dsmax 2011
                      Prateek Vishwa
                      sigpic
                        did you do any calculations with the physics stuff?
                        Colin Senner
                          naa nothing.. here is the floor plan which i was trying to do..
                          Prateek Vishwa
                          sigpic
                            Go to utilities, click on the reactor tab, go to collisions and clear them.
                            if you merge anything from that file (material/object) it'll bring all the collisions with it again. and again, every time you do it. if you've done a lot of merging from infected files it can build up and spread pretty easily.
                              use this command:
                              deleteTrackViewController trackviewnodes TrackViewNodes.Max_MotionClip_Manager
                              Surrealismo
                              https://www.facebook.com/surrrealismo
