problem with volume light: standard light vs photometric light
  • problem with volume light: standard light vs photometric light
    Hi everyone!
    I want to create a spotlight (!) - based on a photometric light - with an atmospheric volume light effect. So far no problem at all.
    BUT: Rendering the scene with vray (2.10.01) lets the fog appear very noise ... not to say brutally ugly.
    When I create a spotlight - based on a standard light - with the same atmospheric volume light effect, the rendered scene looks fine.
    Can anyone reproduce that phenomenon and - much better - give a solution to me?
    Thanks for an answer
    JanClick image for larger version
ID:	873731Click image for larger version
ID:	873732Click image for larger version
    Is your noise threshold set low ? Are your global sub d's high enough ?
    Regards
    Steve
    My Portfolio
      Is it a VRayIES light or a 3ds Max one?
        Thanks for your answers.
        I just tried to increase the noise threshold and the global subdivs - but it did not give a satisfiable solution. The volume-fog of the light is still noisy - not as much as before but the noise is still there and the rendertime grows brutally!
        I even tried to change the images sampler type (from adaptive subdivision to adaptive DMC) and played with the settings - but still the same effect.
        Finally I had the idea to change the type of the Antialiasing filter - it also did not help.
        I definitely do think that the problem is not on the site of the vray-render-settings, because the volume-fog of a standard-light and nearly any other light looks brilliant with my vray-settings!
        The photometric light only shows the effect when I switch the "distribution type" to "spotlight"!
        If I use it as an "Uniform diffuse", "Uniform spherical" or even as an "photometric web" with an assigned IES-file the volume-fog look fine.
        What am I doing wrong?
          Also thanks for your answers, Vlado.
          IES-light does not show the effect.
          Please read my reply to stevesideas.
          Thanks
          Jan
            Well, if you can post your 3ds Max scene, it will be helpful. I could not reproduce the problem here in a simple test.
              Done!
              You can find it in the ZIP-file together with a rendered image.
              Thanks for your effort.
              Jan
                Thanks; I think it's a problem with the 3ds Max photometric light - I get the same problem with the scanline renderer too. I'm not sure what can be done about it. You could try using the VRayEnvironmentFog, but it's not quite the same.
