Never recieved this error before installing the update of vray. DR buckets for render nodes just render black...even after restarting vrayserver on each node.
render nodes - failed to receive irradiance map (3) error
Posting because I don't want you to feel alone, I've been following the thread waiting for more info.
I'm having similar issues on the farm. I can set up a farm machine to render the IR maps in prepass mode, but when I set a net render job out to the farm in animation - rendering mode none of the slaves can read the maps. Bummer... (yes they're all set to 2.20.02)
Rendering locally works fine though...
Also noticing that sometimes I sent a range of frames for pre-pass rendering such as -5 to 498, and for some reason the job on backburner thinks I only sent an 8 frame job. Doesn't happen every time though... removing job and resubmitting fixes it.
EDIT: Now some jobs just have "unexpected errors" and don't render at all on the farm... again pre-pass rendering.Last edited by Deflaminis; 21-12-2011, 06:12 PM.
