VRayHairMtl and motion blur problem
If you used the 3ds Max Hair&Fur for this, you need to go into the hair emitter object properties and enable the Object motion blur setting as described here: http://www.spot3d.com/vray/help/200R...er_hairfur.htm
You may also have to adjust the motion blur options in the Hair&Fur render effect, as they are the ones that will be used to determine the motion blur interval for the hair, rather than the V-Ray settings for duration, interval center etc.
VladoI only act like I know everything, Rogers.
