VRayHairMtl and motion blur problem
  • VRayHairMtl and motion blur problem
    Recently I've made a test that shows that VRayHairMtl works only with camera motion blur.
    With static camera it looks like this:
    Is it a bug, or have I some bad setup?
    gomo.pl
    If you used the 3ds Max Hair&Fur for this, you need to go into the hair emitter object properties and enable the Object motion blur setting as described here: http://www.spot3d.com/vray/help/200R...er_hairfur.htm
    You may also have to adjust the motion blur options in the Hair&Fur render effect, as they are the ones that will be used to determine the motion blur interval for the hair, rather than the V-Ray settings for duration, interval center etc.
      Seems to work
      Sorry for rising a problem, I have to learn read documentation more carefully :/.
      And thanks for help.
      gomo.pl
