Possible Bug With Vray 2.20.01 and Backburner
  • Possible Bug With Vray 2.20.01 and Backburner
    When I render through Backburner, VrayDisplacement Modifier on objects is disregarded.
    Same file renders fine without Backburner.
    Regarding the problem:
    - The displacement type used: Subdivision (I didn't try with other displacement types so problem could be only with subdivison or all)
    - The map used in displacement slot : 16bit tiff file inside a VrayBmpFilter map
    I would like to know if I can have a fix for the problem.
    Thanks in advance
    for my blog and tutorials:
    www.alfasmyrna.com
    How come you are using subdivsion and not just a 2d/3d displacement?
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      I didnt understand the question. Why I should not?
      www.alfasmyrna.com
        How come you are using subdivision?
        Are you wanting to use it for "smoothing"?
        Chris Jackson
        Shiftmedia
          There is a 16bit displacement map applied onto it that I created during sculpting.
          I applied it in subdivison mode.
          www.alfasmyrna.com
            Im assuming your displacement map is able to be seen by the network systems...
            Regards
            Steve
            My Portfolio
              Well, this worked fine in my simple test, but I will check out your scene.
