Just cant get rid of Light leaks
  • Just cant get rid of Light leaks
    I have an exterior scene where the building is far in the distance. Some 100 metres away from the camera. I am rendering a 5k image, on the exterior of the building there are light leaks from the interior lights in the building. I am using IR + LC and I ahve tried various methods to try and eliminate the problem.
    I have set the shadow bias of each interior light to 0.001mm, turned on detail enhancement and set the scale to world, 100mm radius and a subdivs multiplier of 0.5. The IR settings HSph subdivs 70, interp samples 30. Check sample visibility is on. LC is 1500 subdivs with 150mm world scale.
    I am running out of options and I am not sure what settings would suffice for this type of scene as the building is so far away from the camera.
    Thanks!
    Adaptive DMC sampler is min 1 max 12. Noise threshold 0.07
      Can you show (a part of) an image? Aslo, what is your secondary GI engine?
        Vlado, I have emailed you. Thanks.
          I had issues like this once on a short film I was doing and after checking everything it turned out to be the objects Xforms...
            its 100m from camera.. how far from max origin is it?
              did you tick "retrace threshold" in LC?
              Kind Regards,
              Morne
                vlado suggested this and it worked I managed to try everything but this setting. Thanks.
