environment background seen through none refractive object
  • environment background seen through none refractive object
    I have a simple scene where an object that has no reflection or refraction is placed over a viewport background. The background map is also in the 3ds Max environment. The background map is set to screen as I want to be visible within the render. However when I render you can see the background through the object. it is as if the object is transparent but it is not.
    Any ideas?
    It is the same issue that is mentioned here http://forums.cgarchitect.com/63284-...y-objects.html
      You need to specify a different map or color to be used as the GI environment.
        Yeah I figured that out in the end. Can I ask why you need to do that though?
