Glossy reflection bug (?)
  • Glossy reflection bug (?)
    DMC 1-100 produces visible polygon edges in glossy reflections, at least in some situations. DMC 1-4 no problems (at first... see next post).
    Both renders have color threshold 0,005. Metal material has 8 Reflection samples.
    DMC 1-100 (vertical stripes near the left and right edges)
    DMC 1-4
    I attached the test scene. The lower object is just a torus and the top one is a bended box.
    3ds max 2013
    VRay 2.30.01
    Why am I posting this? Well, we've had some problems with this before.. especially with glossy reflections that have anisotropy. In this example anisotropy didn't seem to affect the error.
    - Teemu
    TD at http://brinkhelsinki.fi
    3ds Max 2013 with VRay 2.30.01.
    Win 7, Intel Xeon X5675, Nvidia Quadro 5000, 48 gb ram.
    Adding heavy bump (20) seems to reproduce the problem with DMC 1-4 also.
      Have you tried turning on the "Fix dark glossy edges" option in the VRayMtl BRDF options?
        That seems to fix it almost fully. There is only a hint of the polygon structure left, which is very manageable. Thank you very much, vlado!
        - Teemu
          Well... using bump still seems to make the polydon edges visible.
          - Teemu
            Yep, VRayNormalMap might work better.
              Thanks again, that seems to fix everything.
              - Teemu
