Vray sky white and glass problem
  • Vray sky white and glass problem
    I'm having a problem with my Vray sky being only white.
    I'm using Vray sun and Vray phyical camera
    I have a Quadro 4000 graphic card
    Also I can't seem to get tranpanent glass. Even if I download the glass from The Vray material de site. It only seems to reflect.
    I have carefully followed all the tuts etc.
    I'm new at using vray.
    I am using version Vary2 The last update before the 2013 one
    Also 3dsmax 2012 design
    Can anyone suggest what is wrong?
    For the white sky problem, are you using a Vray Physical camera? The sun and sky by default are very powerful to match the real world, you'll need a Vray Physical Camera with appropriate settings to expose it correctly. Also double check that the Vray Sky map is in your environment slot.
    James Hall
    Technical Director
    New Zealand
    www.jhall.nz
      Yes I am using the phyical camera.
      I'm petty sure I have the Vray Sky map but I will check.
      Thanks for the help.
        http://en.wikipedia.org/wiki/Sunny_16_rule
        On a sunny day and with ISO 100 film / setting in the camera, one sets the aperture to f/16 and the shutter speed to 1/100 or 1/125 second (on some cameras 1/125 second is the available setting nearest to 1/100 second).
        On a sunny day with ISO 200 film / setting and aperture at f/16, set shutter speed to 1/200 or 1/250.
        On a sunny day with ISO 400 film / setting and aperture at f/16, set shutter speed to 1/400 or 1/500.
