V-Ray license Server Service
  • V-Ray license Server Service
    Recently my render machines are not able to obtain a license using the vray license server service. I think the only change has been the 2.3 update.
    Launching the license server through the shortcut seems to work however. What could cause this?
    Thanks,
    York
    Hi York.. could it be the same problem that I had?
    http://www.chaosgroup.com/forums/vbu...r-service-quot
    I hope Vlados answer can help you.
      Did you actually register the V-Ray license server to run as a service?
        Sorry, I don't know what happened. I just tried it again and it seem to be working ok.
        Thanks
          I also have this problem. Every time when i click the shortcut to launch the Vray it seems like always pop a box said there is an error or something not found. I have to try to launch the Vray a several time. What caused this?
            What does the error box look like? What is the message?
              Today launch the Vray but no any error message pop up. Weird. Sometimes have sometimes don't. Next time will screen capture the error message for you if happen again. But i hope this won't happen anymore.
                Vlado,
                1. Launch the Vray license.
                2. WK1118 error message pop up.
                3. After closed it, vrlservice.exe:Start error pop up.
                4. Try to launch the lincense again.
                5. Success.
                If lucky, only try one time. If not, got to try a several times. May i know what caused this problem?
                Here areClick image for larger version
Name:	Vray error when launch it.jpg
ID:	845577Click image for larger version
Name:	Vray error when launch it 2.jpg
ID:	845578 the screen capture of the error.
                Thanks for reply.
                  Please try the following:
                  Go to Start menu- Chaos Group- Licensing- Administration- Remove V-Ray license service
                  Then register the license service again and go to Control Panel- Services, right click and start the license service.
                  Let us know if the error appears again.
                  Zornitsa(Zori) Simeonova
                  Technical Support
                  tel: +359 2 422 422 1
                  tel: +359 2 489 44 86
                  fax: +1 818 4751567
                  www.chaosgroup.com
                  Technical Support
                  Chaos Group
                    Technical Support
                    fax: +1 818 4751567
                    www.chaosgroup.com
                    Thanks for your reply.
                    These few days Vray didn't pop up any error anymore before i try the steps provided by you.
                      Technical Support
                      fax: +1 818 4751567
                      www.chaosgroup.com
