Wrong light count and long render times
  • Wrong light count and long render times
    I'm trouble shooting some long render times, and I notice something. The V-Ray dialog box says I have 3 light, but I only have two, and it says it's rendering from camera "V". The camera I'm rendering from is named, "Vray Physical Camera. I have a lot of proxies, and modest render settings (see below), but my times are through the roof. Currently my, "Building Light Cache..." is 27 hrs. I turned my displacement off, so it's not that.
    my settings:
    LC Subdivs 800 - size 0.015 (screen)
    LC Prefilter samples 32
    IM Min -6 Max -2 Real Hsph 36 - Interp 28
    DMC - Glog.mult 2.0
    DMC - Adapt 0.9 - Noise 0.01
    Glossies: 14 - Shadow : 10
    AA: 1-3 - ClrThr 0.015
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    The third light is a "GI" light used for producing GI on Standard materials.
    The "V" is in 3ds Max 2013 only, where we missed a few cases where we need to convert strings from Unicode to MBCS.
    What is your dynamic memory limit set to?
    Best regard,
      I see... it just looked odd. My memory limit is set to 0 auto.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Then it might be due to some material; what happens if you override the scene materials with a default grey one?
          let me try that.
          I'm getting the render host is not responding, too. I have already shut down everything once, but that didn't resolve anything.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            actually, it has gotten worse. The light cache started at 158hrs and is jumping fast; it's currently at 358hrs
            it's also takes a long time updating instances.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              here is the model, if you care to take a peek. I have spent the entire day trouble shooting this. The attached zipped file contains the model, without the proxies, or texture maps.
              http://www.sendspace.com/pro/dl/5fu3o6
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                Okay. It might be multiscatter. I've used it before, with a lot more geometry, without issues. I've already tried with it off, or at least I thought, and it still rendered slow. Now, with it off, it's rendering perfectly.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  it's definitely multiscatter. I removed the multiscater helper, manually copied just as many proxies, and it renders fine. I posted over in i-cube's site, but things usually go unanswered over there.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    another issue, on the same project, but not a Multscatter problem. I can't render anything larger than 1700x1100, and If I try, none of the slaves respond. I can ping the machines, so they are available. I do have compress on save enabled, since it is a large file, but nothing. The warnings pops up instantly, as if it's not even trying to communicate, and the slaves all show 100% RAM usage. Something is happening, but it's not rendering. I have all my assets copied locally, on all the machines, so it's not transferring much. I tried letting it run over night, thinking they will eventually engage, but they never do. When I drop the resolution down to 1700 X 1100 all the machines start participating like they should.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      I rendered out a lower resolution successfully, so I thought I would try to inch up the resolution, but none of the slaves engage during the pre-pass. I'm rendering out a 3400 x 2200, and only the main workstation is processing, but all slaves are running at 100%. They are using all their resources, so much that it takes 5 minutes to access the services, but they are not contributing to the pre-pass. I'm not getting any errors in the VRay Message log, either. In an earlier try I get warning that the irradiance map failed to copy (or something to that effect).
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        Bobby,
                        Without having looked at your scene have you got any "penetration" on your multiscatter?
                        Chris Jackson
                        Shiftmedia
                        www.shiftmedia.sydney
                          I removed the multiscatter, which helped the render times, but still none of the slaves are helping out with irradiance map.
                          Originally posted by jacksc02 View Post
                          Bobby,
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            If you look at the the V-Ray log file on the render slaves, what does it say?
                            • #15
                              The log file is to long to post, but it has a lot of this:
                              Validity for node "X" is [forever], node handle is XXXX
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
