Wrong light count and long render times
  • #16
    here is today's log. I took the spawner out of the services, and started the spawner manually. the V-Ray messages show the scene being loaded, but nothing is showing up in the buffer, yet.
    [2012/J/9|09:00:00] 70 % completed.
    [2012/J/9|09:00:00] 80 % completed.
    [2012/J/9|09:00:00] 90 % completed.
    [2012/J/9|09:00:01] Setting up 4 thread(s)
    [2012/J/9|09:00:01] 14 % completed.
    [2012/J/9|09:00:02] 23 % completed.
    [2012/J/9|09:00:02] 31 % completed.
    [2012/J/9|09:00:02] 47 % completed.
    [2012/J/9|09:00:02] 56 % completed.
    [2012/J/9|09:00:03] 65 % completed.
    [2012/J/9|09:00:03] 74 % completed.
    [2012/J/9|09:00:03] 82 % completed.
    [2012/J/9|09:00:03] 90 % completed.
    [2012/J/9|09:00:04] Threads completed
    [2012/J/9|09:00:04] 10 % completed.
    [2012/J/9|09:00:04] 20 % completed.
    [2012/J/9|09:00:04] 30 % completed.
    [2012/J/9|09:00:04] 40 % completed.
    [2012/J/9|09:00:05] 50 % completed.
    [2012/J/9|09:00:05] 60 % completed.
    [2012/J/9|09:00:05] 70 % completed.
    [2012/J/9|09:00:05] 80 % completed.
    [2012/J/9|09:00:06] 90 % completed.
    [2012/J/9|09:00:06] Setting up 4 thread(s)
    [2012/J/9|09:00:06] 13 % completed.
    [2012/J/9|09:00:06] 22 % completed.
    [2012/J/9|09:00:07] 31 % completed.
    [2012/J/9|09:00:07] 47 % completed.
    [2012/J/9|09:00:07] 56 % completed.
    [2012/J/9|09:00:08] 64 % completed.
    [2012/J/9|09:00:08] 72 % completed.
    [2012/J/9|09:00:08] 82 % completed.
    [2012/J/9|09:00:08] 90 % completed.
    [deleted a bunch of the same]
    [2012/J/9|09:10:27] Threads completed
    [2012/J/9|09:10:27] 10 % completed.
    [2012/J/9|09:10:28] 20 % completed.
    [2012/J/9|09:10:28] 30 % completed.
    [2012/J/9|09:10:29] 40 % completed.
    [2012/J/9|09:10:29] 50 % completed.
    [2012/J/9|09:10:29] 60 % completed.
    [2012/J/9|09:10:30] 70 % completed.
    [2012/J/9|09:10:30] 80 % completed.
    [2012/J/9|09:10:31] 90 % completed.
    [2012/J/9|09:10:31] Updating render lights
    [2012/J/9|09:12:01] Setting up 4 thread(s)
    [2012/J/9|09:12:01] Threads completed
    [2012/J/9|09:12:01] 33 % completed.
    [2012/J/9|09:12:01] 66 % completed.
    [2012/J/9|09:12:01] Updating atmospheric effects.
    [2012/J/9|09:12:01] Updating render effects.
    [2012/J/9|09:12:01] Scene setup: 1077.3 s
    [2012/J/9|09:12:01] Compiling render instances geometry.
    [2012/J/9|09:12:01] 10 % completed.
    [2012/J/9|09:12:01] 20 % completed.
    [2012/J/9|09:12:01] 30 % completed.
    [2012/J/9|09:12:01] 40 % completed.
    [2012/J/9|09:12:01] 50 % completed.
    [2012/J/9|09:12:02] 60 % completed.
    [2012/J/9|09:12:02] 70 % completed.
    [2012/J/9|09:12:02] 80 % completed.
    [2012/J/9|09:12:02] 90 % completed.
    [2012/J/9|09:12:02] Compiling lights geometry.
    [2012/J/9|09:12:02] Preparing ray server.
    [2012/J/9|09:12:02] Creating and initializing 4 thread(s).
    [2012/J/9|09:12:02] Allocating memory for build data of 1590822 faces (12726576 bytes, 12.1 MB).
    [2012/J/9|09:12:02] Initializing face build data.
    [2012/J/9|09:12:03] Creating 'done' event.
    [2012/J/9|09:12:03] Starting first thread.
    [2012/J/9|09:12:03] Waiting for thread completion.
    [2012/J/9|09:12:03] 19 % completed.
    [2012/J/9|09:12:03] 29 % completed.
    [2012/J/9|09:12:03] 41 % completed.
    [2012/J/9|09:12:03] 54 % completed.
    [2012/J/9|09:12:04] 64 % completed.
    [2012/J/9|09:12:04] 72 % completed.
    [2012/J/9|09:12:23] Releasing thread resources.
    [2012/J/9|09:12:23] SDTree statistics:
    [2012/J/9|09:12:23] Total number of faces stored: 1590822
    [2012/J/9|09:12:23] Max tree depth: 57
    [2012/J/9|09:12:23] Average tree depth: 28.7825
    [2012/J/9|09:12:23] Number of tree nodes: 717779
    [2012/J/9|09:12:23] Number of tree faces: 5160337
    [2012/J/9|09:12:23] Number of tree leafs: 279535
    [2012/J/9|09:12:23] Average faces/leaf: 18.4604
    [2012/J/9|09:12:23] Memory usage: 160.22 MB
    [2012/J/9|09:12:24] Scene bounding box is [-1909.22,-1870.46,-106.254]-[2355.93,2295.16,970.429]
    [2012/J/9|09:12:24] Preparing direct light manager.
    [2012/J/9|09:12:24] Preparing global light manager.
    [2012/J/9|09:12:24] Irradiance sample size is 84 bytes
    [2012/J/9|09:12:24] Broadcasting NOTIFY_PRE_RENDERFRAME.
    [2012/J/9|09:12:24] beginFrame() done.
    [2012/J/9|09:12:24] Broadcasting NOTIFY_BEGIN_RENDERING_ACTUAL_FRAME.
    [2012/J/9|09:12:24] Photon size is 56 bytes.
    [2012/J/9|09:12:24] Light cache sample size is 120 bytes.
    [2012/J/9|09:12:24] Building light cache.
    [2012/J/9|09:12:24] Tracing 640000 image samples for light cache in 8 passes.
    [2012/J/9|09:12:24] Setting up 4 thread(s)
    [2012/J/9|09:12:24] Light cache time interval is (0.000000, 100.000000)
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #17
      I also looked in the main workstation's spawned log. It said something about not being able to open the ini, so it's using the default. I'm not sure this means anything.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
      • #18
        In that case I'll have to ask for the scene; you can send it to vlado@chaosgroup.com and I'll check it out.
        • #19
          I just sent it, thanks!
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
          • #20
            I also noticed, in the VRSpawner.log, that it is referring to 3ds MAX Design 2011 - I'm running 3DS MAX 2013
            "C:\Program Files\Autodesk\3ds Max Design 2011\network\vraydummy2011.max"
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
            • #21
              and...
              6: [2011/May/11|13:47:44] VRaySpawner temp dir: "C:\Program Files\Autodesk\3ds Max Design 2012\network" 7: [2011/May/11|13:47:44] Application name (MAX/VIZ): "C:\Program Files\Autodesk\3ds Max Design 2012\3dsmax.exe"
              8: [2011/May/11|13:4
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
              • #22
                I just stumbled across something, that might, or might not, be an issue. When I went to archive the project, my compression application said that some files are in use, but everything pertaining to the project is closed. The files that didn't zip are all vrmeshes.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                • #23
                  different project, but same issue. Everything was fine, MAX crashed, and now my LC just climbs to astronomical numbers!
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                  • #24
                    and just like last time, I get an error about the MAX saving path not being valid. I didn't have a saving path enabled, which is odd. The only saving path I had was in PSD manager. My light cache.... is now at 598 hours, and climbing!
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                    • #25
                      I have narrowed my issue down to trees. It doesn't matter which trees, from my library, I use. When I turn my trees off, it renders fine. I have tried proxies, but it isn't any better.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                      • #26
                        Okay! it must be a bug. I turned my trees off (only three trees), rendered a couple tests, and then I turned my trees back on. When I turned my trees back on it rendered fine. I didn't do anything, except turn them off, and back on again.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
