VRayEnvironmentFog to only show where lights are?
  • VRayEnvironmentFog to only show where lights are?
    Hi all
    OK so I need the VRayEnvironmentFog to just be VRayFog if that is possible? In other words I only want fog in the beam of my light. Kinda like Volumetric lights work in max with scanline and standard lights.
    Is this at all possible?
    Kind Regards,
    Morne
    anybody have a clue?
    Kind Regards,
    Morne
      You can use a cylindrical or conical gizmo to limit the volume effect just within the light cone.
        for now I'm using it as is because my situation is a bit more complicated. I have a rectangular light shining through a complex "slot".
        Using more or less defaults with the distance tweaked a bit, is actually working not too bad...
        Maybe I would use your cylindrical suggestion to make aircraft search lights
        Kind Regards,
        Morne
