has anyone else come across this issue?
the render appears to be fine on the LC pass, but then turns out pink in the IRmap pass...
it's a revit model imported as fbx into max design 2012, with a mixture of revit and vray materials.
i'm using vray 2.30.01
scene is lit externally with vray sun + sky and has a few standard max spots internally.
if i do a region render the scene renders normally.
also, moving the camera slightly changes the 'pinkness'
