V-Ray Sun causes weird shadow glowing
  • #16
    Thanks for the subpixel mapping option! I usually have that checked. Not sure what happened. Anyhow, that fixed it! Much thanks.
    I'll certainly send over the project once I get it 'out the door' to the client.
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    • #17
      Any ideas for settings to check for the blotchy stuff going on on the side of this unit? The light is from a V-Ray Plane that's shooting though the window. The window has glass in it, but clear (Refraction 255). It's probably another setting that I don't understand
      THANK YOU so much for everyone's help!
      Dave
      David Anderson
      Software:
      Windows 10 Pro
      Hardware:
      Puget Systems
      TRX40 EATX
      128GB RAM
      • #18
        You can try to uncheck "refractive" GI caustics from Indirect illumination tab.
        Tashko Zashev | chaos.com
        • #19
          Well, that certainly fixed the issue, but killed the window light... I'll try cranking up the panel light intensity and see if that will work. Maybe that's the reason that my V-Ray sun was blowing out the entire scene, even at a low intensity...
          David Anderson
          Software:
          Windows 10 Pro
          Hardware:
          Puget Systems
          TRX40 EATX
          128GB RAM
          • #20
            Dummy me... The glass material that was in the windows didn't have 'enable shadows' ticked, so I wasn't getting *any* light through the windows, V-Ray Plane, Sun, or other. Once I figured that out, it seems that things are working much, much better, even with Refractive GI caustics enabled. Yippee!
            What would be a good source for V-Ray training, both in print and on-line?
            Thanks again!
            David Anderson
            Software:
            Windows 10 Pro
            Hardware:
            Puget Systems
            TRX40 EATX
            128GB RAM
            • #21
              Hello Streetwise
              Chaosgroup offers online trainings - for more information please send a request to veselina.zheleva@chaosgroup.com - she is the person who is responsible for questions about Vray Training.
