Where is the lens effects render element?
  • Where is the lens effects render element?
    So there is bug with glare where it basically ruins the whole image. How can I just save the lens effects source as a render element so I can add glare in post? Is there a way too get the lens effects as a render element? Or is that also bugged. Is there any way to get this to work?
    See my reply here: http://www.chaosgroup.com/forums/vbu...164#post566164
    Out of curiosity, can you show me what the bug looks like?
      Can't show it for a few weeks, but it renders with the rgb channels out of place and they streak across the image. Doesn't happen all the the time, it seems really random.
        Hello CMoss,
        Do you still have this issue ?
        If yes could you please send us a screen-shot of the error , and example scene.
        Thank you advance.
          I get this also a lot while trying to tweak the glare settings. Saving and opening will most times hide\fix the issue. The only way to recreate it (in any scene) is to fiddle with the glare settings and hit update effect a lot.
          That being said, sometimes the effect is quite cool, like an oldfashioned analogue light leak into the camera casing....sort of.
          Signing out,
          Christian
            I think this was fixed in the latest builds...
              Latest being 2.30.01?
              That is what I'm using.
              Signing out,
              Christian
                Could you please send us an e-mail to support@chaosgroup.com about this issue, so we could send you a build to test.
                Zdravko Keremidchiev
                  Here is what it looks like.
                  Sometimes it's just one channel though.
Name:	Glare artifacts.jpg
                    Which V-Ray build is that?
                      version 2.30.01
                        If you send us an e-mail to support@chaosgroup.com we will send you a build to test.
