Layered glass getting darker and darker
  • Layered glass getting darker and darker
    Hi everyone.
    I have a general problem with layered glass. Every layer is getting darker and darker - even if I do not look through them - they are just stacked behind each other, all sharing the same material. See the image of a simple scene - some blocks with a fully refractive material and a pure white environment color, no GI, no gamma-correction or anything.
    I know in finalRender there was an option to define the energy loss for each tracing, but I do not find this kind of option in VRay.
    But I´m not sure if it is a tracing-problem, because in the image the block in the back is the darkest - even if two rays should be enough to trace through the surfaces to fully see the background.
    Setting every cutoff possible to zero and cranking up the "Max Depths" for reflections and refractions does not solve the problem...
    ...well, cranking up the "Max Depths" (e.g. 200) at least does something, but it makes it more and more weird...
    Anyone any suggestions?
    Is it possible to let´s say trace through 100 sheets of glass without loosing energy?
    I also added a simple test-scene...
    Thank you and kind regards.
    Sascha
    I can't open that file maybe done in upper version than 3ds max 2011, in my opinion, (I do a lot of renders with glasses), is better to avoid the inside faces of the 3 layered boxes u always get a gradient in their borders as shown in your image and plus u'll get darker shadows from those distinct objects close each others (I'd avoid complete overlapping faces between their faces). To avoid the effect of a gradient color from their borders merge the 3 boxes in unique mesh and delete the inside faces, u'll get the correct shadows less dark respect distinct objects. Hope it can help, my english is not so good. If I'll have time I'll attach a little file
    Workstation: Asus p9x79WS I7 3930K Noctua NH-D14@4200GHz SE2011 16GB RAM Kingston Hyperx Beast SSD 500Gb Samsung x2 SATA3 WD raid edition4 64MB GTX760 2GB DDR5 CoolerMaster 690III
    https://www.facebook.com/essetreddi..../photos_albums
      Hi pengo.
      Thank you for your tips, that is a cool idea if the block stays always attached. But I don´t think this fits my needs, because the layered block itself is the plot - I have to show the assembeled block and then I have to show all the layers one by one - so I cannot delete inner faces.
      I think in worst case I have to use this trick blending between opacity-mapped inner faces to make them invisible while assembled - but that is very timeconsuming and I will have a visible gap while blending...
      Sascha
        Is there no way to get this fully transparent?
        Still struggeling and I do not get a good result.
        Regardless of rendertimes - is there a way to get these glass-blocks looking really transparent?
        I figured out that the reflections are the problem - if I turn them of the block is fully transparent without any loss of lightness. If I turn on the reflections every iteration seems to steal something from the lightness - resulting in a darker and darker look.
        Please I would really appreciate if anyone has a solution for me.
        I link two max-files - its the same for max 2011 and 2012 - and attach a rendering from what I get.
        http://www.deepartmend.de/tl_files/e...m_max_2012.zip
        http://www.deepartmend.de/tl_files/e...m_max_2011.zip
        Help...
        Sascha
          yes there is something weird going on here
          if I apply my own glass material to your objects, I get it in reverse
          then it starts of dark, and goes lighter
          even if I recreate your objects, I still get the same result
          Kind Regards,
          Morne
            if you delete the big inner polys, then it works perfect
            Kind Regards,
            Morne
              Yes, this happens if the max depth for reflections and reflections are too low to represent the count of the faces that have to be traced. In my example I have to trace through 7 layers which means at least a depth of 14 is needed for reflections and reflections to trace through. Setting this to the default of 5 leads to the effect you described - but now the traces can´t see through the whole block. The break-even is 8 for both - lower than this leads to darker front, higher than 7 leads to darker back...
                Yeah, pengo mentioned that, but I can´t delete them, because I have to show all layers individually in an animation...
                  although, "perfect" is debatable:
                  Kind Regards,
                  Morne
                    Sorry I missed that part the 1st time around...
                    Kind Regards,
                    Morne
                      ok got a fix
                      Instead of the planes each being a small distance from each other, rather make each one overlap the previous a bit. That seems to work
                      this time its perfect(ish), well its getting there
                      Kind Regards,
                      Morne
                        [ATTACH=CONFIG]12253[/ATTACH]
                        Is this with deleted inner polys? Looks weird...
                          yes that was
                          But my second test with them overlapping seems to work more or less like you want. There is still darkening to the front, but it is a whole lot less obvious than what it was
                          Kind Regards,
                          Morne
                            ok got a fix
                            [ATTACH=CONFIG]12254[/ATTACH]
                            Awa - thats interesting...
                            ...didn´t try this...
                            I´ll check it...
