So, after having issues with Backburner crashing 3dsMax upon hitting the submit button (repeatedly, didn't matter what scene or contents), I thought I'd look into some other farm management solutions. I've loaded up a demo of SquidNet, and it seems promising, but I'm having an issue with it too. I create a new render job (in Squidnet) and submit it to the farm, however according to the log, as soon as Vray loads up the job errors out. "An unexpected exception has occurred in the network renderer and it is terminating." I'm testing this both on my local machine and on a slave located in the same subnet as well. Same result. I'll post the full log from SquidNet below. The Vraylog.txt file shows nothing (pasted below as well). I'm curious if you guys at ChaosGroup have tested out SquidNet at all and if you know why it may not be working? One thing I have noticed, and I will be mentioning this to the guys at Squidnet, is that in the 3dsmax CLI command, the output filename has an added "\" between the path and the filename. I don't see a way for me to get around that from the Squidnet interface. But I'm also somewhat doubtful that's what's causing the crash. Anyway, here is the data from the logs. Any help would be appreciated!
SquidNet's log--------------
Application nodename match found. Replacing appliction path '3dsmaxcmd.exe' with 'D:\3ds Max 2012\3dsmaxcmd.exe'. (Profile==3DSMAX2012)
Command Path: ["D:\3ds Max 2012\3dsmaxcmd.exe" -JPEG_QUALITY 90 -showRFW 1 -start:1 -end:1 -nthFrame:1 -showRFW:0 -v:5 -outputName "G:\12038 - SXXXXXXs - Simon Revs 2\renders\\test1.jpg" -rfw:0 "G:\12038 - SXXXXXXXs - Simon Revs 2\max\5x8ft RMU-03.max"]
APPLICATION log starting:
Execution command: [d:\SquidNet\tmp\\82228104-squid-ndm-1354231858-1.bat]
C:\Windows\system32>"D:\3ds Max 2012\3dsmaxcmd.exe" -JPEG_QUALITY 90 -showRFW 1 -start:1 -end:1 -nthFrame:1 -showRFW:0 -v:5 -outputName "G:\12038 - SXXXXXXXs - Simon Revs 2\renders\\test1.jpg" -rfw:0 "G:\12038 - SXXXXXXXs - Simon Revs 2\max\5x8ft RMU-03.max"
11/29/2012 16:30:58 PM; Parsing scene: "G:\12038 - SXXXXXXXs - Simon Revs 2\max\5x8ft RMU-03.max"
11/29/2012 16:30:58 PM; 1 frames initialized
Max install location: D:\3ds Max 2012\
11/29/2012 16:30:58 PM; Max file being rendered: G:\12038 - SXXXXXXXs - Simon Revs 2\max\5x8ft RMU-03.max
11/29/2012 16:30:58 PM; Renderer: V-Ray Adv 2.10.01
11/29/2012 16:31:08 PM; [V-Ray] ================================================== ==========
11/29/2012 16:31:08 PM; [V-Ray] Console created, V-Ray Adv 2.30.01 for x64 from May 3 2012, 01:25:30
11/29/2012 16:31:08 PM; [V-Ray] Compiled with Intel C++ compiler, version 12.1
11/29/2012 16:31:08 PM; [V-Ray] Host is 3dsmax, version 14
11/29/2012 16:31:08 PM; [V-Ray] V-Ray DLL version is 2.00.01
11/29/2012 16:31:08 PM; Error rendering frame 0: An unexpected exception has occurred in the network renderer and it is terminating.
11/29/2012 16:31:08 PM; Send End of Job command to Max
11/29/2012 16:31:09 PM; Job Completed with Error(s) - see above
11/29/2012 16:31:09 PM; Total elapsed time 376175:28:05
11/29/2012 16:31:09 PM; Max is down
11/29/2012 16:31:09 PM; Error occured while rendering job.
C:\Windows\system32>set retvar=3
C:\Windows\system32>IF NOT ERRORLEVEL 0 set retvar=3
C:\Windows\system32>cmd /c exit /B 3
APPLICATION log ending:
SquidNet Job Statistics:
Application exit Status: 3 (0x3)
Application expected Status: 0 (0x0)
Processing Start time: Thu Nov 29 16:30:58 2012
Processing end time: Thu Nov 29 16:31:10.269
Application log file limit: 0 bytes
GHZ Hours used: 0.085604 bytes
Max CPU Frequency: 3502 MHz
Application log file size (allocated): 10000 bytes
Total Processing Time: 11s
Max memory used in processing slice: 393492 KB
Template : 3D Studio Max
Job Id : rmu test
Frames : 1 - 1
Processing Node name : DIGITAL-20
Version : 2.66P83
Administrator Account : John Pruden
Time : Thu Nov 29 16:30:58.958
VrayLog.txt--------------------
[2012/Nov/29|16:31:08] ================================================== ==========
[2012/Nov/29|16:31:08] Console created, V-Ray Adv 2.30.01 for x64 from May 3 2012, 01:25:30
[2012/Nov/29|16:31:08] Compiled with Intel C++ compiler, version 12.1
[2012/Nov/29|16:31:08] Host is 3dsmax, version 14
[2012/Nov/29|16:31:08] V-Ray DLL version is 2.00.01
Job Id : rmu test
Frames : 1 - 1
Version : 2.66P83
