VRaySoftBox material doesn't update in slate material editor
  • VRaySoftBox material doesn't update in slate material editor
    When I create multiple soft box materials and select them in the slate material editor the settings don't change. It keeps the same settings/gradients as what was previously selected. Only work around I have found is to select a non soft box material first and then select the other soft box material. Only then do the settings update to that material.
    Seems OK in 3ds max 2013 but in 2012 it's not
      Thank you very much for your feedback.
      I have the same result from my tests - I'll add this bug into our system.
        you are welcome
          Another bug i think...
          After saving out a material library of soft box lights. When I try and load them in the compact material editor, they don't load as the library shows nothing in it. Tried ticking show incompatible etc but doesn't make a difference. However they load up fine in the slate material editor.
            Can you get me such a library?
              What do you mean by "soft box lights" ? Just soft box textures ? LightMtl + Softbox ?
              If you save textures in material library and load that library in the compact editor, you will see them only if you are choosing Texture for a texture slot - doesn't matter that you can put textures in material slots in the compact editor.
              Peter Matanov
              Chaos
                ah sorry, of course. As the softbox material is a texture it wont show in the compact material editor when loading a library unless, as you mention choosing a texture for a texture slot. I don't use it much since the slate material editor so I am used to seeing everything in a custom material library which includes textures
