Originally posted by joconnell
View Post
If you have 8 light samples , and AA DMC 1/4 - Vray will fire Maximum 8/4=2 samples per camera ray, but since the absolute minimum samples in DMC SAMPLER (not DMC image sampler) is 2 - as a result Vray will shoot exactly 2 light samples per camera ray - because minimum and maximum samples per ray in this situation is 2.
If in the same example we have default minimum samples value - which is 8 , Vray will always fire 8 samples per camera ray regardless "calculated" maximum samples = 2.
Please have in mind that I mention only "samples" here not subdivisions. The parameter in Light options is called "subdivisions" - this is important to know because if you enter 8 in this field you actually set 64samples = 8x8.
