Alpha renders incorrectly on shape instances in particle system
  • Alpha renders incorrectly on shape instances in particle system
    Hey there.
    I wanted to use particles for distribution of a simple plane for an ordinary corona effect.
    For unknown reasons, the particle shape instances do not render the opacity correctly. The referenced plane however renders just fine.
    I am not quite sure that this is even a VRay related issue, but you might be able to help me anyways.
    Here is what I get on the particle instances. In the viewport you can see the source plane right next to it, which renders as intended:
    Let me know if you need any other information.
    Thank you very much for the feedback.
    I did a quick-test but everything on my side was working as expected.
    Could you please send us your scene - and inform us what 3DSMax and Vray versions you are using.
    Thank you very much in advance.
      It looks like there are duplicate faces there...
        Hey!
        thanks for the help, it was indeed a problem with more then one face at the same position due to errors within the particle distribution
