Hoping someone has figured this out. I saw a thread but no solution. I'm rendering an animation and I've precalc'd the IR for the sequence. When I send it to backburner for render, some objects are rendering black. If I render the same frame using the precalc'd solution directly in Max it renders fine. Checked for flipped normals and the material is fine. Seems to be an issue only through BB???? I've tried about everything I can think of and can't find a solution. Below are pics:
Here's the frame rendered directly in max with the exact same settings as the BB job:
This is the same frame rendered through BB on the same machine:
These are the settings:
I don't even know what to try next. That piece at the bottom renders fine as a single frame or part of the animation sequence directly through max so I don't understand how it could be an issue with that piece of geometry. Am I correct in understanding that BB/spawner on slaves uses a standalone version of vray? Could the issue be w/ the standalone version? I'm at a loss (and on a deadline of course). The other odd thing is that I've rendered this before and didn't have this issue. Same settings, machines etc. It "might" have been w/ an older version of vray though.
