The diffuse color of my material renders darker when I use an opacity map. If I use the same map in the refract slot it renders as expected. In the attached image the diffuse color of the diamond perforated material should be the same color as three stripes of solid gray materail. The material above the red marks used a refraction map. The material below the red marks uses an opacity map. Neither uses both refract and opacity at the same time. Solid and perf materials have the same reflection settings. The objects are planes.
Created in Max2014. Saved as Max 2012.
Vray 2.40.03
Windows 7 64bit
perf mat 2012.zip
Vray 2.40.03
Windows 7 64bit
perf mat 2012.zip
