Cancel
  • Cancel
    I am not sure if it is just me, or if it is just how it is, but canceling a render takes forever. I can wait 15 minutes for a render to cancel, and even longer when I am using PDF Manager.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Which V-Ray version is this?
      I am using 2.40.04
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Ok, I think we had a problem like this that we fixed at some point, but I have to check if it went into 2.4
          Bobby, aren't you using SolidRocks? I have an issue where it says "restoring materials" after render finish that sometimes takes very long. Do you see that message?
            It might be a combination of the two, but it doesn't happen with only solidrocks.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              I closed SolidRocks, started a render and I let it run for about 15 minutes, and hit cancel. This is what I am looking at for 27 minutes!
              When I don't use PSD-Manager, the render stops in seconds.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                psd-manager does nothing when the render was cancelled. However, before the render it will request the creation of certain G-Buffer channels that it may need (only if you use any of the mask generation features). So that is the only influence I can imagine if you cancel mid-render. The G-Buffer is handled entirely by 3ds max + V-Ray.
                Here is a test to figure out if 3ds max/V-Ray maybe has trouble with the G-Buffer cleanup after the render:
                Remove the psd-manager effect and try rendering to RPF format. In the RPF setup dialog enable the channels Material-ID, Object-ID, Node-Render.ID, Coverage, Transparency, Sub-Pixel-Weight. This will cause the 3ds max Framebuffer + G-Buffer to be created by 3ds max/V-Ray (similar to what psd-manager would usually request).
                Daniel
                Daniel Schmidt - Developer of psd-manager
                  We get this too. So annoying with all the little delays. The add up over the course of a day/week/month...
                  Kind Regards,
                  Richard Birket
                  http://www.blinkimage.com
                    it has to be something in V-Ray. I say this, because when I change how I am rendering (different settings), I don't get the delay. same model, same everything, except different v-ray settings.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      So is it possible to get us a scene that reproduces this to vray@chaosgroup.com ? We might be able to fix this.
                        yes. let me work on getting you the scene when it is being difficult.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          it seems to be a multiscatter issue. New project, pretty simple one, and multiscatter is mucking things up.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            I guess multiscatter doesn't like proxies. I have been fighting this screen all day, and I tracked it down to multiscatter objects. When I got rid of the proxies, everything started to render fine.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
