Vray 3 beta - Could not obtain license (-200)
    Still not working...
    License server working, reinstalled vray 3.0, reinstalled wibu-box drivers, in max still message "Could not obtain a license (-200)".....whats wrong?
    regards Christoph
      What happens if you try to render? Do you get an error message in the V-Ray message log? If yes, what is it?
        ...i get this message: see attach.
        regards christoph
          Would it be possible to run a remote session on your machine in order to find out what exactly is the issue ?
          If yes please send remote-session-request to support@chaosgroup.com and include a link to this thread.
          We are looking forward to hearing from you.
            ...I installed vray 3.0 on a clean machine (without parallel running vray 2.4)....now it works!
            regards christoph
            • #21
              Thank you for your feedback.
              • #22
                Hi, i ask for and extended time frame on beta licence, upgraded the dongle licence, the same problem "could not obtain licence -200), check the licence server,
                Product 0x766130 Total Engaged Free
                Render licenses 0 0 0
                Interface licenses 1 0 1
                DR licenses 0 0 0
                so i remove dongle
                uninstall wibu driver
                download wibu
                install wibu
                plug dongle
                NOTHING HAPPENS.
                What can i do?
                Is it going to be the same with every release?
                Arch Pedro A. Solano
                "Save the irradiance map, save the render"
                Vray 3.10.03|3DMax 2011 x64|Intel Core i7-2600 CPU @3.4GHz|16GB Ram|Windows 7 Ultimate SP1
                Follow us on facebook
                Visit us on PSolano
                • #23
                  Originally posted by oligophant View Post
                  What can i do?
                  It looks like you are using an old license server (it says Product 0x766130)?
                  • #24
                    And how i can get/use an updated licence server?
                    i attach what i see on the licence server page.
                    Visit us on PSolano
                    • #25
                      Is your license server the same machine you installed VRay 3 onto?
                      If not, you need to install the updated license server onto the computer hosting your VRay licenses. Once you have done that, all the licenses will work correctly.
                      Troy Buckley | Technical Art Director
                      Midwest Studios
                      • #26
                        Installed vray3 on my dongle pc, everything work as expect, but i have a question, if i want to work on 2.4, Do the licence server downgrade by doing that? or it keeps the new one. I want to test 3 on another pc
                        btw: i owe you a beers troy
                        Visit us on PSolano
                        • #27
                          You should still have your 2.4 license and a VRay 3 license.
                          If the "other" pc is on the same network, just install VRay 3 on it, and then point the license to the machine with the VRay 3 License server, should be good to go. The 2.4 license should not be affected.
                          Unless I misunderstood the question.
                          Midwest Studios
                          • #28
                            Well, the cookie crumble this way for me.
                            Main dongle pc (workstation)
                            installed vray 3
                            license server information, everything its as expected,
                            installed vray 3 on slave pc, everything its as expected.
                            i want to use vray3 on slave pc and work with 2.4 on main pc ( i have some projects going on atm)
                            deinstall vray3 on main pc and install vray2.4
                            license server information doesn't recognize vray3 licence, it says "Product 0x766130"
                            Seems that i cannot have vray2.4 and vray 3 on slave pc. Also i have only max2011, maybe if i install max2014, but for now i would like a workaround. Anyideas?
                            Visit us on PSolano
                            • #29
                              installed vray 3
                              Oh, I see; a bit unusual configuration. Well, one solution would be to install V-Ray 3.0, copy the file vrlservice.exe somewhere (it is in "c:\program files\chaos group\v-ray\3dsmax NNNN for x64"), install V-Ray 2.4, and then copy the vrlservice.exe file from the 3.0 installation over.
                              Best regrds,
                              • #30
                                Thanks, i'll do that; the thing is that it worked fine with the previous release, so i got confused.
                                Visit us on PSolano
