Vray Frame Buffer
  • Vray Frame Buffer
    Hi
    The problem as follow : when I click on Vray Frame Buffer after the end of any render 3dsmax goes in error what's wrong?
    I have 3dsmax 2013 and Vray 2.40.04
    Can you help me
    Thank's
    Daniele
    sorry for my bad english
    What kind of error?
      What kind of error?
      I was wrong I mean crash
      when render is done if I click on any button on VFB 3dsmax goes in crash
      Best Regards
      Daniele
        Does it happen every time or it appears just randomly ?
        Have you tried to reinstall Vray , if not please do it and run the same test again.
        If the issue still persist please send us an email to support@chaosgroup.com in order to schedule remote meeting.
          Same big problem here....
          VRB causes an 3dsmax APPHangB1...!!
          Reinstall vray 3.01 does´nt help...switch to direct3d viewport does´t help
          merge in new scene..no results...
          3dsmax 2014 x64...
          ..any solutions???
          best regards
          chris
          www.vis-art.de
          www.facebook.com/visart3d
            Does it happen for this scene in particular? If yes, can you send it to us to vray@chaogroup.com so that we can reproduce the problem and fix it?
            Also, if you get the 3ds Max CER dialog after the crash, can you send me the latest 3dsmax_minidump.dmp file from your temp folder (type %temp% in Windows Explorer to go there) to vlado@chaosgroup.com - it will tell me what crashed and where.
              Hello vlado,
              find the bug! There was standard normal map inside a vray proxy... switched to vraynormalmap brings the solution.... seems to be a bug, when using standard normal map inside a vray proxy...
              www.vis-art.de
                Ohh yes, there is that. We need to report it to Autodesk...
