I have installed 3dsmax design 2014 64Bit and SP3. After having installed V-Ray 3.0 my 3dsmax menus don't appear on software startup. Instead it says "-- Unknown system exception".
The MAXScript Listener has logged this message:
-- Error occurred in registerVRayMenus(); filename: C:\Program Files\Autodesk\3ds Max Design 2014\scripts\startup\vrayutils.ms; position: 85692; line: 2780
-- Frame:
-- registerVRayRTMenus: undefined
-- called in updateVRayMenus(); filename: C:\Program Files\Autodesk\3ds Max Design 2014\scripts\startup\vrayutils.ms; position: 85902; line: 2791
-- Frame:
-- called in autoinstallVRayUI(); filename: C:\Program Files\Autodesk\3ds Max Design 2014\scripts\startup\vrayinstall.ms; position: 556; line: 14
-- Frame:
-- Error occurred during fileIn in #C:\Program Files\Autodesk\3ds Max Design 2014\scripts\startup\vrayutils.ms; line number: 2780
>> MAXScript Auto-load Script Error - C:\Program Files\Autodesk\3ds Max Design 2014\scripts\startup\vrayinstall.ms Exception:
-- Unknown system exception <<
Pls could you provide help with this problem? My 3dsmax isn't usable any more, because I have no menubars!
Thank you very much in advance!
Lars
-- Frame:
-- Frame:
-- Frame:
Lars
