LC trouble with old scene rendered with VRay 3
  • LC trouble with old scene rendered with VRay 3
    I installed VRay 3 and tried to render a VRay 2.x scene. But the LC creates strange looking black dots:
    I tried to use Brute-Force instead which works fine.
    If I activate "Probabilistic lights" the LC problem is gone as well. So there might be an issue with light in my scene?
    Can you get me a part of the scene that causes the problem to vlado@chaosgroup.com? I noticed a similar issue with one scene recently, but I want to double-check so that we can fix this ASAP.
      Ok, it looks like there are some VRay lights in this scene which really do not "like" an hedge object. If I hide the lights OR the hedge, everything renders fine. Otherwise LC calculation lasts for hours. The black dots might have something to do with this thing.
      I will send you the file Vlado.
        Any news concering this issue?
          I'm actually looking into it now; I will let you know as soon as I find anything.
            Hello there, was there a resolution to this issue? I am running into the same thing here.
            Thanks for any updates.
              The particular issue in that scene was fixed a long time ago. If you still have something like this, then the cause is probably different and it would be best to get us a scene to support@chaosgroup.com
