GI pass issue with thinkbox Deadline
  • GI pass issue with thinkbox Deadline
    Hello ChaosGroup
    we got a GI pass issue with thinkbox Deadline
    This is incorrect GI pass img
    we often use Tiles Render with Deadline
    like this
    we submit Render job to deadline
    when deadline start rendering it render speed is very very very slow
    we compare with local render GI pass
    we are not so sure issue come form Vray or Deadline
    the issue File has already sent
    Thank you, we will check the ticket now and reply to you as soon as possible.
    Tashko Zashev | chaos.com
      thank your reply
      we checked the ticket
      it is the "Deadline's tile rendering" without any V-Ray Distributed rendering
        we use simply test and clarify what happen with deadline
        override scene with simply mat
        like this:
        we test two difference GI method
        First one is Brute Force and Light cache
        other one is Irradiance map and Light cache
        BF+LC
        it seems like some slaves get stuck in Prepraring scene stage
        other slaves is rendering with slow speed
        here are local slave status
        other one
        Irradiance + LC
        it get suck in final bucket
        hope help anything
          Thank you for your details.
          We are doing some tests now and will reply to the ticket as soon as we have any information about this issue.
            hello
            we have tested same issue for a while
            we notice one thing about this issue
            difference GI turn on or off
            GI turn off with local render
            GI turn off with Slave render
            both of render time are very close (the test look like work fine with deadline)
            so we guess GI turn on could be cause some bug or something
            hope help anything
              Hello again,
              Have you received our last reply from the ticket system?
              The slow down appears because Deadline calculates Light Cache for the entire image for each tile. So if you have for example 60 tiles Deadline will force Vray to calculate 60 times Light Cache not only for the current tile but for the whole image. In order to avoid that please pre-calculate LC before submitting the scene to the Deadline and load it from file. With that setup the slowdown wouldn't appear.
              The latest versions of Deadline already has a support for Vray Distributed Rendering - this would be even better solution than Tiled-Rendering , have you tried it ?
