White Background
  • #16
    I have never gotten this to work; I don't think it has ever worked.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    • #17
      Turning the vrayLight dome to "full dome" solve the issues.
      If full Dome is not checked, the dome will always be visible in the background whatever I tried. I don't understand why, but from my test, it is how vray works.
      • #18
        Taking future the test, I confirmed the following:
        - The vraylight must be "Full Dome"
        - 3Dsmax environment must have a Vraycolor map with RGB multiplier set very high (I put 10 this this camera setup).
        - uncheck affect background in the color mapping rollout
        In this test scene, I found the following irrelevant:
        - GI environment doesn't have to be turn on (with or without give exactly the same floating value on the background).
        - Vignetting on or off, doesn't affect the color background value
        - White balance color doesn't affect the color background value
        So no need to mess around with all this parameters to get a white background.
        • #19
          You can do it this way as well: http://www.workshop.mintviz.com/tuto...lective-floor/ Also remember to turn off affect alpha in the dome light.
          • #20
            thanks, the double Dome light save my issues of getting ride of the HDRI reflexion on the plane.
            Thanks
            • #21
              I've often struggled with this and each time I have to come find this thread to solve it, and it does. But, I've also found you don't even need the Dome light, at least in Max 2023. I have a scene with just the VRayBitmap with 'RGB Multiplier' set to 37 in the'Environment Map' Slot ( shortcut key = 8 ). It gives me a 255,255,255 background with pure silohouette of my meshes.
              V-Ray 6.20.06, 3ds Max (3D Studio thru Max 2025), GIGABYTE X570 AORUS Master Motherboard, Ryzen 9 3950x CPU, Noctua NH-D15S CPU Cooler, 128 GB G.SKILL Trident Z Neo DDR4 Ram, NVidia RTX 4090, Space Pilot Pro, Windows 11, Tri-Monitor, Cintiq 13HD
              Autodesk Expert Elite Member
