I have never gotten this to work; I don't think it has ever worked.
White Background
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- ​Windows 11 Pro
Taking future the test, I confirmed the following:
- The vraylight must be "Full Dome"
- 3Dsmax environment must have a Vraycolor map with RGB multiplier set very high (I put 10 this this camera setup).
- uncheck affect background in the color mapping rollout
In this test scene, I found the following irrelevant:
- GI environment doesn't have to be turn on (with or without give exactly the same floating value on the background).
- Vignetting on or off, doesn't affect the color background value
- White balance color doesn't affect the color background value
So no need to mess around with all this parameters to get a white background.
You can do it this way as well: http://www.workshop.mintviz.com/tuto...lective-floor/ Also remember to turn off affect alpha in the dome light.
thanks, the double Dome light save my issues of getting ride of the HDRI reflexion on the plane.
Originally posted by JamesCutler View PostYou can do it this way as well: http://www.workshop.mintviz.com/tuto...lective-floor/ Also remember to turn off affect alpha in the dome light.
Originally posted by fraggle View PostTaking future the test, I confirmed the following:
So no need to mess around with all this parameters to get a white background.Last edited by RobH22; 13-04-2023, 01:17 PM.------------------------------------------------------------
V-Ray 6.20.06, 3ds Max (3D Studio thru Max 2025), GIGABYTE X570 AORUS Master Motherboard, Ryzen 9 3950x CPU, Noctua NH-D15S CPU Cooler, 128 GB G.SKILL Trident Z Neo DDR4 Ram, NVidia RTX 4090, Space Pilot Pro, Windows 11, Tri-Monitor, Cintiq 13HD
Autodesk Expert Elite Member
- Likes 1
