Black artifacts all over render
  • Black artifacts all over render
Name:	Render issue.jpg
    I had this very strange issue when rendering with version 30003 for MAX 2014.
    Turning off Embree seems to resolve the problem, but it would be nice to take advantage of the speed increase that this feature is intended to provide.
    Looks like the problem which I have described here: http://forums.chaosgroup.com/showthr...ed-with-VRay-3
    If I understood Vlado correctly, it might be an issue with the noise map.
      Originally posted by DeadLift315 View Post
      [ATTACH=CONFIG]18530[/ATTACH]
      Any chance to send this scene for investigation ?
      We could provide FTP if needed.
        I had this very strange issue when rendering with version 30003 for MAX 2014. Turning off Embree seems to resolve the problem, but it would be nice to take advantage of the speed increase that this feature is intended to provide.
        It would be very useful if you can get us a scene as Svetlozar suggested. We fixed a number of these cases already, but it would be good to check your scene too.
          Uploaded an archive to FTP and sent the information to support@chaosgroup.com
          Thank you for your help!
            I am having this same issue. I have tried switching from light cache to brute force as mentioned in Mirko's post, but that did not remove them. I have not tried turning off Embree yet like Deadlift315 advised. I have uploaded an archive of the scene to my webserver. 22mb, mostly from a Jeff Patton HDRI
            http://www.jtwo.com/vray/vraytestblackdots.zip
              This seems to be one of the issues that we fixed for the next patch; for the moment you can avoid it by using the native spherical mapping of VRayHDRI rather than the one in the "Coordinates" rollout.
                That worked perfectly, thank you.
                  Argh, I am having the same problem.
                  I do use the native shperical mapping so what can I do to remove those horrible black dots?
ID:	851558Click image for larger version
                  Stefanie
                  https://renderkitchen.com/
                    Email me to vlado@chaosgroup.com ...
                      I have the same black dots but only its showed on render node, the other nodes render fine. Im using native spherical mapping also. This is an old project started on 2.4 but i have recently create a new set of materials on 3. How could i solve it?
                      update:
                      Even without that render node black dots are back, i have 9 cameras and on some of them there are black dots, and rest not so its maybe, the camera?, also a warning show up "texture map#8 returned an invalid bump normal (XYZ -1 #qnan, -1.#qnan), but that particular map was replaced so there is no map#8. That warning was present on the begining of my rendering session, that's the reason i replaced to fix that warning.
                      Arch Pedro A. Solano
                      "Save the irradiance map, save the render"
                      Vray 3.10.03|3DMax 2011 x64|Intel Core i7-2600 CPU @3.4GHz|16GB Ram|Windows 7 Ultimate SP1
                      Follow us on facebook
                      Visit us on PSolano
                        Hi, oligophant, apparently NormalMaps in VrayProxies cause the black dots, so you should replace them by VrayNormalMaps.
                        If that doesn't help, get the latest Nightly Build of the support team, no more black dots there...
                        Stefanie
                          Thanks Stefanie, i email vlado to get access, i hope it fixes because i have no normalMaps on my scene
                          Visit us on PSolano
