Trouble getting Render Node running
  • Trouble getting Render Node running
    I have an install of Vray 3 for MAX running on my main workstation. (dynamic IP 192.168.1.2)
    I have an additional node to run on my 2nd workstation (dynamic IP 192.168.1.10). Install went fine. Update to the dongle went fine.
    On both machines, I can access the license server via “getstatus” and all appears well…see attached for both images.
    Problem is, when I try to send a network job, the 2nd workstation can’t get the license.
    I’ve tried updating the “license server” to the 1st workstation’s IP address using the “Change v-ray client license settings” but it will not allow me to save it, replying: “V-ray error” “could not save settings”
    I’ve also tried setting up a distributed render adding my 2nd workstation (using name of the machine and port range 30304), AND successfully “resolving servers”. However, I get the following error upon render:
    “warning: could not connect to host 192.168.1.10:30304: connection timeout”
    “warning: could not use of the selected (1) hosts for distributed rendering!”
    I suspect I’m missing a semi-colon or something somewhere, but I’m not savvy enough to know where.
    Any intel/advice you could suggest would be profoundly appreciated.
    Thanks!
    - Geoff
    The general thing I usually do is:
    Disable Firewall everywhere to start with
    Then
    Start node manually not using vray installer/service or any other pre-defined way. Just by hand as administrator.
    That should work in most of the cases, then u can backtrack it and figure it out.
      Problem solved by uninstalling VRay, and specifying the dongle's IP during re-install.
      - Geoff
        Glad to hear you sorted it out
        Let us know if it happens again.
