Is Vray Lens Effects broken?
  • Is Vray Lens Effects broken?
    Maybe im not doing something right
    A. VrayLight
    1. Create vray light
    2. Effects> VrayLensEffects> Bloom on, Glare on, Check on Interactive,
    3. Render
    4. Nothing happens, I get just the white sphere and no effects
    5. Play with parameters , nothing happens again.
    B. Sphere with VrayLightmat
    1.Create sphere
    2. Apply vraylightmat
    3. Effects> VrayLensEffects> Bloom on, Glare on, Check on Interactive,
    4. Render
    5. Nothing happens, I get just the white sphere and no effects
    6. Play with parameters , nothing happens again.
    max2011x64 ; nightly 3.05.05, IRRA+LC
    Did i miss something to make it work?
    Arch Pedro A. Solano
    "Save the irradiance map, save the render"
    Vray 3.10.03|3DMax 2011 x64|Intel Core i7-2600 CPU @3.4GHz|16GB Ram|Windows 7 Ultimate SP1
    Follow us on facebook
    Visit us on PSolano
    Lens Effects will be probably removed from Environment Panel since they work a bit buggy if at the same time they are activated from VFB.
    I did a quick test and I got the same behavior here but they worked fine from from VFB.
    Could you please try to activate them only from VFB window and run the same test?
Name:	2014-04-11 12_01_07-Untitled - Autodesk 3ds Max  2014 x64  - Not for Resale.png
      Thanks Svetlozar, i missed that little icon on the VFB.
      Visit us on PSolano
