Dancing VFB
  • Dancing VFB
    I know that this was talked about before, but a quick search didn't give me any results. What causes the dancing VFB window? Not only is in annoying, it is almost impossible to save a render from the buffer. Is there a fix or known cause?at2f2hw5
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    progressive refinement in the viewport
      With Nitrous.
        and where is that?
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          click on the little plus in the top left of the viewport, and under display performance switch off 'improve quality progressively'
            It didn't solve it. I thought it did, but it has returned. I rebooted MAX, and it seemed to have worked, but with the 'improve quality progressively' still off, it's still dancing around.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Which 3ds Max version is this by the way?
                3DS MAX Design 2014
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  Ok. I think we can add an option or an env. var to not parent the VFB to the 3ds Max window - this will solve the problem, but in that case the VFB might get hidden behind the 3ds Max window. Of course, we could also make it "always on top", but that might be more annoying.
                    I'll be on 3DS MAX 15 soon, and it doesn't happen all the time, so I am personally fine.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      By any chance are you using Project Manager by K-Studio? I love the script, but have found that it suppresses the VFB to the background. Really annoying. The behavior sounds similar to what you are experiencing.
                        no, I am not.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
