I have a strange issue with progressive rendering that keeps popping up. I've rendered out about 50% of the animation using this method (using DR too) but I've come to a point in the animation where objects are animated slicing (not sure if this is the problem) and the render just sits there doing nothing. I've checked the system performance and 3dsmax is at 1%. Almost like it's on pause. None of the DR machines are working either. If I stop the render and start from the same frame the render starts working fine. Then it will do the same thing on a frame further down the line.
Progressive rendering issue
Just a quick update. Max has crashed twice in the last 20 mins whilst trying to render this animation. Something I do not normally get. It started when I upgraded to vray 3 and started using progressive method.
Update: Another crash on the same frame after restarting max. I'll try another method of rendering to see if it does the same thing. Very frustrating that this is happening !Last edited by stevesideas; 13-05-2014, 06:42 AM.
