Matte Shadow with camera map
  • Matte Shadow with camera map
    Im working with an interior view, the backplate its a panorama photography that i shoot myself and i have to place furniture and accesories, so i place my camera and from there a started to model a lowpoly version of the apparment in order to use camera map to project the photo. So far so good. I cant use the photo projected on the render because it have so many little details that are better handled in photoshop, so i that the material projected and wrap it on a vrayMtlWrapper.
    VrayMtlWrapper parameters
    But i can't get the shadows or the reflections from it, also it looks like the matte doesnt react as a shell and gets shadows projected from the outside where it wasnt expected to be a light
    How could i address this problem? I have 3 more views where the shadows and reflections are a big deal, im on a deadline by the way.
    Arch Pedro A. Solano
    "Save the irradiance map, save the render"
    Vray 3.10.03|3DMax 2011 x64|Intel Core i7-2600 CPU @3.4GHz|16GB Ram|Windows 7 Ultimate SP1
    Follow us on facebook
    Visit us on PSolano
    Actually it will be very difficult to help you with this workflow without seeing the entire scene setup and V-Ray settings.
    The RGB and Alpha Matte renders have totally different shadow casting from the first Camera map picture.
    Would it be possible to attach the scene file or send to support@chaosgroup.com ?
    Tashko Zashev | chaos.com
      Tashko, im going to send the files to support right now.
      Visit us on PSolano
        Thank you for the scene file.
        The wrong render of the matte object is caused by the reversed polygon normals. Try to select the entire matte object (the walls), then edit poly > Element > select all > Flip (Edit elements section)
        Unfortunately matte surfaces doesn't respect the Double sided property yet.
          Tashko, It worked with the flip faces, im going to do another one with reflections more evident.
          Thanks so much.
          Visit us on PSolano
