Backburner - Split render + Vrimg failed
  • Backburner - Split render + Vrimg failed
    Hello,
    Because DR is unpredictable (some node failed, never the same, sporadically), I tried to used backburner instead.
    But using BB + split render + save to raw image file return an error : Cannot create outpout image file
    The same job assigned to only one node is successful!
    What am I doing wrong?
    I would try running managers and so on on ur slaves as administrator. Could be rights issue.
      Thanks,
      "and so on", what does it means?
      "severals", with s? Does it make sense to run several managers?
      I have "server" run as service on the slave, and manager started manually on the Workstation.
        Hey
        Sorry I was referring to all the BB utilities. What is it Server, Manager, Monitor?
        I think I wanted to say to run Servers on slaves in administration mode just in case they dont have the rights to save image. Or maybe you dont have folder for it and they cant create folders. Not sure.
          Hey
          Thanks,
          when split is not used, the file can be save. I tried on 5 servers and I don't get any problem to write the file.
          Writing standard Jpg file in split mode works fine with several servers too.
          So I guess it has something to do with the vrimg file format and split function of BB.
            Uhh... I suppose it's because vrimg is vray based and split is max based...humh.
            If you are using Split renderingthen you might as well render directly to exr. You wont have memory issues anyway.
              You're right, I will forget about vrimg and save as exr, this format at least should be compliant with max.
                Yea it should work just fine. If I'm not wrong even layered EXR's should work.
