I made 2 custom presets, one for fast+low quality and one for slow+high quality rendering. When I load them with the presets button under system properties, all works well and I can switch between the two. Only this needs a lot of clicks if I want to switch between the two.
So when opening the quick settings, I can simply click the preset rollout and chose my custom preset. For example I first select the fast preset, render and it works. Then I select slow and again this works. But then when I select slow again, only some settings update. In this case for example the min/max and subs of IR map change to my fast settings, however the global DMC settings remain the same as my slow settings.
Does anyone else experience this behavior?
Thanks,
Wouter
Thanks,
Wouter
