The License Server 3.0 Only installer and a multi-byte character problem.
  • The License Server 3.0 Only installer and a multi-byte character problem.
    With "The License Server 3.0" Only installer currently released by ChaosGroup account
    It will become an error if an installer is The License Server 3.0 Only installer with a multi-byte character path.
    And, in XP, if a multi-byte character user name is used, installation will not be successful.
    Please check and FIX
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    Hi Flat,
    Reproduced and forwarded to the developers.
    Thank you very much for your feedback.
    Tashko Zashev | chaos.com
      Our developers managed to fix this, but only for the internal builds. If you need it urgent, please contact us at support@chaosgroup.com
        Ok, Thanks
        mails later.
        oakcorp.net
        v-ray.jp
          Actually you could workaround it by using the latest V-Ray 3.00.07 and choose "License server only" installation type. It will install the same license server version as the one available on our web site, but without the plugins.
