I have a very unusual problem with my vray license. After a few years of working with Vray without any bigger issues, after a small update (to 2.5) currently when I restart my PC the vray license service starts automatically, I can run 3ds max and Vray works fine. But after a while (could be 15 minutes, could be an hour) 3ds Max is unable to see the license service ("could not obtain license (-200)" ). Shutting the vrlservice.exe manually via task manager and starting the license service again, manually gives this error:
vrlservice.exe: Start Error
One of the following licenses are required:
* WibuKey 250897:7758101
Failure reason: A WibuBox with the specified Serial Number was not found (18 ).
I uninstalled vray and installed it again. Nothing. The Wibu server on Windows 8 doesn't work with the provided drivers, but this whole "disappearing" license thing happens with both the default drivers that come with the Vray installer and the newer ones that are available on the Wibu website. Also deactivating the firewall didn't help.
Some general info:
OS - windows 8.1 Pro
3ds Max 2014 and 2015
Vray 25001 installed as a local workstation
Contacted support on Saturday and so far no answer, but would really appreciate if someone could point me in the right direction with this one. It's Monday and as you might expect I need to work
Some general info:
