glossy refractions knocking out alpha
  • glossy refractions knocking out alpha
    If you create a material and make the refract colour non black and glossiness amount less than 1.0. The alpha for the objects it is applied to is grey even if there is a fully opaque object behind.
    Is this a bug or intended?
    Cheers,
    Olly
    Set V-Ray class properties en masse with the VMC script
    Follow me for script updates: @ollyspolys
    I worked fine in my quick tests - would it be possible to send us a sample scene along with the result you got in your environment.
    Let us know which Vray version you are using.
      please find the file attached below - we are using vray 3.00.07 and max design 2014 sp5
      glossy refractions knocking out alpha.zip
      Thanks,
      Olly
        This is a know bug with Affect All Channels option in Refractions in version 3.x which is not fixed yet - switch to Color+Alpha and it should work as expected.
