Skipped rednder node - WHY? VRay 2.5
  • Skipped rednder node - WHY? VRay 2.5
    Why would a render node be skipped if the spawner is up and running and waiting for a job?
    ...and it even says "rednder" node
    Then little later it tries again and this time it is "Render" host
    Ok I can live with the typo, but why would it be skipped in the 1st place?
    AND, while we're on the subject, can we get some consistency please. It sometimes shows node name and other times IP address depending on where it is in the progress. It would be nice to have a setting in DR to display either IP, Node name, or Both at all times
    Kind Regards,
    Morne
    I double checked, in my DR settings max servers is set to 0. Also restared max, still nothing
    Also tried the reverse, added a ridiculous high number in there, makes no difference
    Kind Regards,
    Morne
      It was them darn aliens I tell you!
      After restarting the entire pc, the issue went away
      Kind Regards,
      Morne
        I've seen this happen before, like you said restarting 3ds Max usually helps. Not quite sure why yet.
          In my case restarting max DIDNT help. I had to restart the whole pc for it to go away
          Kind Regards,
          Morne
            Hi Morne,
            Something that you may try is to delete the vray_dr.cfg file from the workstation as soon as this issue appears again and refill the DR settings window with all DR nodes. Then run another DR job.
            The .cfg file could be found here :
            C:\Users\[User_name]\AppData\Local\Autodesk\3dsMax\[Version_Number] - 64bit\ENU\en-US\plugcfg
            Tashko Zashev | chaos.com
              Thanks, I'll try it next time it happens
              Kind Regards,
              Morne
